FLUSEPA - a Navier-Stokes Solver for Unsteady Problems with Bodies in Relative Motion : Toward a Task-Based Parallel Version over a Runtime System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2015
FLUSEPA code is designed to handle unsteady problems with bodies in relative motion (stage separation) and strong shocks. A finite volume formulation is used to solve the RANS equations. Time integration consists on an explicit temporal adaptive solver. We present a task based parallel version of the aerodynamic solver designed from the previous MPI/OpenMP one and using a modern runtime system to schedule the tasks. An Ariane 5 booster separation computation will be presented.
SIAM CSE.pdf (2.76 Mo) Télécharger le fichier
hal-01255440 , version 1 (13-01-2016)
  • HAL Id : hal-01255440 , version 1
Jm Couteyen Carpaye, Jean Roman, P Brenner. FLUSEPA - a Navier-Stokes Solver for Unsteady Problems with Bodies in Relative Motion : Toward a Task-Based Parallel Version over a Runtime System. SIAM Conference on Computational Science and Engineering (SIAM CSE 2015), Mar 2015, Salt Lake City, United States. 2015. ⟨hal-01255440⟩
1313 Consultations
352 Téléchargements
