Estimates- and Corrector-based Mesh Adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel formulation for the mesh adaptation of the approximation of a PDE. The proposed formulation extends the goal-oriented formulation, since it is equation-based and uses an adjoint. At the same time, it supersedes it as a solution-convergent method. Indeed, goal-oriented methods rely on the reduction of the error in evaluating a chosen scalar output with the consequence that as mesh size is increased (more degrees of freedom) only this output is proven to tend to its continuous analog, while the solution field itself may not converge. A remarkable throughput of goal-oriented metric-based adaptation is the mathematical formulation of the mesh adaptation problem under the form of the optimization, in the well-identified set of metrics, of a well-defined functional. In the new proposed formulation, we amplify this advantage. We search, in the same well-identified set of metrics, the minimum of a norm of the approximation error. The norm is prescribed by the user and the method allows addressing the case of multi-objective adaptation, like, for example in aerodynamics, adapting the mesh for drag, lift,moment in one shot. In this work we consider the basic linear finite-element approximation and restrict our study to L2 norm in order to enjoy second-order convergence. Numerical examples for the 2D Poisson problem and for 3D Euler flows are computed.
PANACM2015_Brethes.pdf (2.23 Mo) Télécharger le fichier
hal-01256111 , version 1 (14-01-2016)
  • HAL Id : hal-01256111 , version 1
Gautier Brethes, Adrien Loseille, Frédéric Alauzet, Alain Dervieux. Estimates- and Corrector-based Mesh Adaptation. 1st Pan-American Congress on Computational Mechanics - PANACM 2015 XI Argentine Congress on Computational Mechanics - MECOM 2015, Apr 2015, Buenos Aires, Argentina. ⟨hal-01256111⟩
159 Consultations
80 Téléchargements
