A Pragmatic Type System for Deductive Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In the context of deductive verication, it is customary today to handle programs with pointers using either separation logic, dynamic frames, or explicit memory models. Yet we can observe that in numerous programs, a large amount of code ts within the scope of Hoare logic, provided we can statically control aliasing. When this is the case, the code correctness can be reduced to simpler verication conditions which do not require any explicit memory model. This makes verication conditions more amenable both to automated theorem proving and to manual inspection and debugging. In this paper, we devise a method of such static aliasing control for a programming language featuring nested data structures with mutable components. Our solution is based on a type system with singleton regions and eects, which we prove to be sound.
main (1).pdf (376.6 Ko) Télécharger le fichier
hal-01256434 , version 1 (14-01-2016)
hal-01256434 , version 2 (28-01-2016)
hal-01256434 , version 3 (01-02-2016)
  • HAL Id : hal-01256434 , version 3
Jean-Christophe Filliâtre, Léon Gondelman, Andrei Paskevich. A Pragmatic Type System for Deductive Verification. 2016. ⟨hal-01256434v3⟩
768 Consultations
459 Téléchargements
