Journal articles
The Euclidean algorithm in quintic and septic cyclic fields
Abstract : Conditionally on the Generalized Riemann Hypothesis (GRH), we prove the following results: (1) a cyclic number field of degree $5$ is norm-Euclidean if and only if $\Delta=11^4,31^4,41^4$; (2) a cyclic number field of degree $7$ is norm-Euclidean if and only if $\Delta=29^6,43^6$; (3) there are no norm-Euclidean cyclic number fields of degrees $19$, $31$, $37$, $43$, $47$, $59$, $67$, $71$, $73$, $79$, $97$. Our proofs contain a large computational component, including the calculation of the Euclidean minimum in some cases; the correctness of these calculations does not depend upon the GRH. Finally, we improve on what is known unconditionally in the cubic case by showing that any norm-Euclidean cyclic cubic field must have conductor $f\leq 157$ except possibly when $f\in(2\cdot 10^{14}, 10^{50})$.
Document type :
Journal articles
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01258906
Contributor : Pierre Lezowski Connect in order to contact the contributor
Submitted on : Thursday, April 28, 2016 - 3:06:06 PM
Last modification on : Saturday, December 4, 2021 - 3:43:27 AM
Long-term archiving on: : Tuesday, November 15, 2016 - 4:39:28 PM
File
quintic_septic_160319.pdf
Identifiers
Collections
Citation
Pierre Lezowski, Kevin Mcgown. The Euclidean algorithm in quintic and septic cyclic fields. Mathematics of Computation, American Mathematical Society, 2017, 86 (307), pp.2535--2549. ⟨10.1090/mcom/3169⟩. ⟨hal-01258906v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
