New interface
Journal articles
Pushdown Module Checking with Imperfect Information
Abstract : The model checking problem for finite-state open systems (module checking) has been extensively studied in the literature, both in the context of environments with perfect and imperfect information about the system. Recently , the perfect information case has been extended to infinite-state systems (pushdown module checking). In this paper, we extend pushdown module checking to the imperfect information setting; i.e., to the case where the environment has only a partial view of the system's control states and push-down store content. We study the complexity of this problem with respect to the branching-time temporal logics CTL, CTL * and the propositional µ-calculus. We show that pushdown module checking, which is by itself harder than pushdown model checking, becomes undecidable when the environment has imperfect information. We also show that undecidability relies on hiding information about the pushdown store. Indeed, we prove that with imperfect information about the control states, but a visible pushdown store, the problem is decidable and its complexity is 2Exptime-complete for CTL and the propositional µ-calculus, and 3Exptime-complete for CTL * .
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01260664
Contributor : Olivier Serre Connect in order to contact the contributor
Submitted on : Friday, January 22, 2016 - 2:41:48 PM
Last modification on : Friday, November 18, 2022 - 9:28:23 AM
Long-term archiving on: : Saturday, April 23, 2016 - 10:42:18 AM
File
comb4-rev.pdf
Identifiers
Citation
Benjamin Aminof, Axel Legay, Aniello Murano, Olivier Serre, Moshe Vardi. Pushdown Module Checking with Imperfect Information. Information and Computation, 2013, 223, pp.18. ⟨10.1016/j.ic.2012.11.005⟩. ⟨hal-01260664⟩
Share
Metrics
Record views
181
Files downloads
97
