Abstract : The feeding of components smaller than 1mm2 is a high challenge in an automated manufacturing line. The surface forces affecting these micro components are getting more important and cause problems when handled. A new method is described using the surface forces for separating, sorting and arranging micro components. The surface shape of fluids and the gravity are used for moving the floating components to defined positions. The components can be arranged in a magazine or can be sorted by a channel system.
Svetan Ratchev. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. Springer, IFIP Advances in Information and Communication Technology, AICT-435, pp.47-51, 2014, Precision Assembly Technologies and Systems. 〈10.1007/978-3-662-45586-9_7〉
https://hal.inria.fr/hal-01260728
Contributeur : Hal Ifip
Soumis le : vendredi 22 janvier 2016 - 15:04:05
Dernière modification le : mardi 3 mai 2016 - 17:04:04
Document(s) archivé(s) le : samedi 23 avril 2016 - 11:03:44
Matthias Burgard, Nabih Othman, Uwe Mai, Dirk Schlenker, Alexander Verl. Feeding of Small Components Using the Surface Tension of Fluids. Svetan Ratchev. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. Springer, IFIP Advances in Information and Communication Technology, AICT-435, pp.47-51, 2014, Precision Assembly Technologies and Systems. 〈10.1007/978-3-662-45586-9_7〉. 〈hal-01260728〉
