Feature selection and complex networks methods for an analysis of collaboration evolution in science: an application to the ISTEX digital library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we aim to give insights about the self-organization of scientific collaboration. To that aim, we describe a new framework to monitor the evolution of a collaboration graph that models the co-authorship of research papers authors. We use community structure of the network as a high-level description of its self-organization and thus consider the evolution of the communities across time. To monitor this evolution, we describe a diachronic analysis method based on the extraction of prevalent nodes for each community. We apply this approach on data issued from the ISTEX project, a scientific digital library that contains so far more than 16 million documents and present some preliminary results and visualizations.
ISKO-Maghreb_2015_submission_42_FINAL.pdf (763.84 Ko) Télécharger le fichier
hal-01231791 , version 1 (20-11-2015)
Paternité
  • HAL Id : hal-01231791 , version 1
Nicolas Dugué, Ali Tebbakh, Pascal Cuxac, Jean-Charles Lamirel. Feature selection and complex networks methods for an analysis of collaboration evolution in science: an application to the ISTEX digital library. ISKO-MAGHREB 2015, Nov 2015, Hammamet, Tunisia. ⟨hal-01231791⟩
366 Consultations
120 Téléchargements
