Dependent Types and Multi-Monadic Effects in F* - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a new, completely redesigned, version of F*, a language that works both as a proof assistant as well as a general-purpose, verification-oriented, effectful programming language. In support of these complementary roles, F* is a dependently typed, higher-order, call-by-value language with primitive effects including state, exceptions, divergence and IO. Although primitive, programmers choose the granularity at which to specify effects by equipping each effect with a monadic, predicate transformer semantics. F* uses this to efficiently compute weakest preconditions and discharges the resulting proof obligations using a combination of SMT solving and manual proofs. Isolated from the effects, the core of F* is a language of pure functions used to write specifications and proof terms---its consistency is maintained by a semantic termination check based on a well-founded order. We evaluate our design on more than 55,000 lines of F* we have authored in the last year, focusing on three main case studies. Showcasing its use as a general-purpose programming language, F* is programmed (but not verified) in F*, and bootstraps in both OCaml and F#. Our experience confirms F*'s pay-as-you-go cost model: writing idiomatic ML-like code with no finer specifications imposes no user burden. As a verification-oriented language, our most significant evaluation of F* is in verifying several key modules in an implementation of the TLS-1.2 protocol standard. For the modules we considered, we are able to prove more properties, with fewer annotations using F* than in a prior verified implementation of TLS-1.2. Finally, as a proof assistant, we discuss our use of F* in mechanizing the metatheory of a range of lambda calculi, starting from the simply typed lambda calculus to System F-omega and even micro-F*, a sizeable fragment of F* itself---these proofs make essential use of F*'s flexible combination of SMT automation and constructive proofs, enabling a tactic-free style of programming and proving at a relatively large scale.
paper.pdf (387.05 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01265793 , version 1 (01-02-2016)
Nikhil Swamy, Cătălin Hriţcu, Chantal Keller, Aseem Rastogi, Antoine Delignat-Lavaud, et al.. Dependent Types and Multi-Monadic Effects in F*. 43rd ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages (POPL), 2016, St. Petersburg, Florida, United States. pp.256-270, ⟨10.1145/2837614.2837655⟩. ⟨hal-01265793⟩
654 Consultations
640 Téléchargements
