Time Efficient Self-stabilizing Stable Marriage
Abstract : “Stable marriage” refers to a particular matching with constraints, in- troduced in the economic context of two-sided markets. The problem has a wide variety of other applications in different domains, such as Cloud computing, Internet content delivery or college admissions. Most of the solutions known up to now are given for the synchronous model, in which executions proceed in rounds, and assume initialization. In this paper, we consider a distributed and asynchronous context, without initializa- tion (i.e., in a self-stabilizing manner - tolerating any transient faults) and with some confidentiality requirements. The single already known self-stabilizing solution [24], based on Ackerman et al.’s algorithm [1], is in O(n 4 ) moves (activation of a single node). We considerably im- prove on this previous result by presenting a solution with an complexity of O(n 2 ) moves (and O(n 2 ) asynchronous rounds), relying on Gale and Shapley’s algorithm [14]. This algorithm runs also in O(n 2 ) moves, but in a centralized synchronous context. Moreover it is not self-sabilizing and a corruption cannot be repaired locally, as noticed by Knuth [21].
Type de document :
Rapport
[Rapport de recherche] LRI - CNRS, University Paris-Sud. 2016
Liste complète des métadonnées
https://hal.inria.fr/hal-01266028
Contributeur : Marie Laveau <>
Soumis le : jeudi 13 septembre 2018 - 16:26:14
Dernière modification le : dimanche 16 septembre 2018 - 01:08:19
Fichier
GSA distributed asynchron.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01266028, version 2
Citation
Joffroy Beauquier, Thibault Bernard, Janna Burman, Shay Kutten, Marie Laveau. Time Efficient Self-stabilizing Stable Marriage. [Rapport de recherche] LRI - CNRS, University Paris-Sud. 2016. 〈hal-01266028v2〉
Métriques
Consultations de la notice
46
Téléchargements de fichiers
38
