Griotte: Improving Code Review with Fine-Grained IDE Events - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Code review is a difficult process because: (1) developers often create tangled commits, (2) a change may be scattered across many different parts of a project, (3) many changes are shadowed, (4) commit messages can be inaccurate or wrong. This work aims to propose a solution to these problems by exploiting the information provided by fine-grained IDE events. To put this solution in practice, we will develop a code review tool named Griotte in the Pharo IDE.
abstract.pdf (133.06 Ko) Télécharger le fichier
hal-01267673 , version 1 (04-02-2016)
  • HAL Id : hal-01267673 , version 1
Skip Lentz, Martín Dias, Damien Cassou. Griotte: Improving Code Review with Fine-Grained IDE Events. BENEVOL'15: 14th BElgian-NEtherlands software eVOLution seminar, Dec 2015, Lille, France. ⟨hal-01267673⟩
306 Consultations
116 Téléchargements
