Balancing Elastic Traffic Sources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Communications Letters Année : 2007
We consider heterogeneous elastic traffic sources that dynamically share a common link. We prove that balancing these traffic sources decreases the mean throughput and increases the blocking probability in the presence of admission control. The result generalizes that of Dartois derived for telephone traffic.
BonaldTran-CL2007.pdf (142.47 Ko) Télécharger le fichier
hal-01275698 , version 1 (18-02-2016)
Thomas Bonald, Minh-Anh Tran. Balancing Elastic Traffic Sources. IEEE Communications Letters, 2007, 8 ; 11, pp.692-694. ⟨10.1109/LCOMM.2007.070393⟩. ⟨hal-01275698⟩
164 Consultations
223 Téléchargements
