Phrase-based Machine Translation based on Text Mining and Statistical Language Modeling Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computational Linguistics and Applications Année : 2011
In this paper, we introduce two new methods dedicated to phrase based machine translation. Both are based on mining a parallel corpus in order to nd out the couples of linguistic units which are translation of each other. The presented methods do not rely on any alignment in contrast to what is done usually by the statistical machine translation community. Each of them proposes a complete translation table containing translations of single words and phrases. The rst method is inspired from the well-known trigger language model while the second one is inspired from the association rules mining technique. All experiments ar e conducted on a large part of EUROPARL corpus and highlight the utility of both proposed approaches.
IJCLA-2011-1-2-pp-193-208.pdf (151.64 Ko) Télécharger le fichier
hal-01270957 , version 1 (20-11-2017)
  • HAL Id : hal-01270957 , version 1
Chiraz Latiri, Kamel Smaili, Caroline Lavecchia, Cyrine Nasri, David Langlois. Phrase-based Machine Translation based on Text Mining and Statistical Language Modeling Techniques . International Journal of Computational Linguistics and Applications, 2011, 2 (1-2), pp.16. ⟨hal-01270957⟩
212 Consultations
157 Téléchargements
