CCS-TA: quality-guaranteed online task allocation in compressive crowdsensing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Data quality and budget are two primary concerns in urban-scale mobile crowdsensing applications. In this paper, we leverage the spatial and temporal correlation among the data sensed in different sub-areas to significantly reduce the required number of sensing tasks allocated (corresponding to budget), yet ensuring the data quality. Specifically, we propose a novel framework called CCS-TA, combining the state-of-the-art compressive sensing, Bayesian inference, and active learning techniques, to dynamically select a minimum number of sub-areas for sensing task allocation in each sensing cycle, while deducing the missing data of unallocated sub-areas under a probabilistic data accuracy guarantee. Evaluations on real-life temperature and air quality monitoring datasets show the effectiveness of CCS-TA. In the case of temperature monitoring, CCS-TA allocates 18.0-26.5% fewer tasks than baseline approaches, allocating tasks to only 15.5% of the sub-areas on average while keeping overall sensing error below 0.25°C in 95% of the cycles
Fichier non déposé
hal-01259541 , version 1 (20-01-2016)
Leye Wang, Daqing Zhang, Animesh Pathak, Chao Chen, Haoyi Xiong, et al.. CCS-TA: quality-guaranteed online task allocation in compressive crowdsensing. UBICOMP 2015 : ACM International Joint Conference on Pervasive and Ubiquitous Computing, Sep 2015, Osaka, Japan. pp.683 - 694, ⟨10.1145/2750858.2807513⟩. ⟨hal-01259541⟩
351 Consultations
0 Téléchargements
