Scalable Shared Memory Multiprocessors: Some Ideas to Make them Reliable - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
Michel Banâtre
  • Fonction : Auteur
  • PersonId : 833460
Christine Morin
Scalable shared memory multiprocessors are promising architectures to achieve teraflops computational power. As they contain a large number of processor and memory elements, such machines have a high probability of failure. In this paper, we investigate an approach based on backward error recovery to provide a highly available scalable shared memory architecture tolerating transient and permanent processor and memory failures.
Fichier non déposé
hal-01275700 , version 1 (18-02-2016)
  • HAL Id : hal-01275700 , version 1
Michel Banâtre, Alain Gefflaut, Christine Morin. Scalable Shared Memory Multiprocessors: Some Ideas to Make them Reliable. Proceedings of the Workshop on Hardware and Software Architectures for Fault Tolerance: Perpectives and Towards a Synthesis, 1993, Le Mont Saint-Michel, France. ⟨hal-01275700⟩
122 Consultations
0 Téléchargements
