Artin-Schreier extensions of normal bases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
David Thomson
  • Fonction : Auteur
  • PersonId : 976946
Colin Weir
  • Fonction : Auteur
  • PersonId : 976947
This manuscript deals with extending a normal basis to a new basis which permits both computationally inexpensive exponentia-tion and multiplication. These new bases are motivated by Artin-Schreier theory, and are particularly useful when creating bases in Artin-Schreier extensions of finite fields.
wcc15-tu1-3.pdf (307.31 Ko) Télécharger le fichier
hal-01275782 , version 1 (18-02-2016)
  • HAL Id : hal-01275782 , version 1
David Thomson, Colin Weir. Artin-Schreier extensions of normal bases. WCC2015 - 9th International Workshop on Coding and Cryptography 2015, Anne Canteaut, Gaëtan Leurent, Maria Naya-Plasencia, Apr 2015, Paris, France. ⟨hal-01275782⟩
Collections
WCC2015
36 Consultations
142 Téléchargements
