Compressive PCA for Low-Rank Matrices on Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal and Information Processing over Networks Année : 2016
We introduce a novel framework for an approximate recovery of data matrices which are low-rank on graphs, from sampled measurements. The rows and columns of such matrices belong to the span of the first few eigenvectors of the graphs constructed between their rows and columns. We leverage this property to recover the non-linear low-rank structures efficiently from sampled data measurements, with a low cost (linear in n). First, a restricted Isometry Property (RIP) condition is introduced for efficient uniform sampling of the rows and columns of such matrices based on the cumulative coherence of graph eigenvectors. Secondly, a state-of-the-art fast low-rank recovery method is suggested for the sampled data. Finally, several efficient, parallel and parameter-free decoders are presented along with their theoretical analysis for decoding the low-rank and cluster indicators for the full data matrix. Thus, we overcome the computational limitations of the standard linear low-rank recovery methods for big datasets. Our method can also be seen as a major step towards efficient recovery of non-linear low-rank structures. For a matrix of size n x p, on a single core machine, our method gains a speed up of p^2 /k over Robust Principal Component Analysis (RPCA), where k << p is the subspace dimension. Numerically, we can recover a low-rank matrix of size 10304 x 1000, 100 times faster than Robust PCA.
FINAL VERSION.pdf (1.94 Mo) Télécharger le fichier
appendices.pdf (485.74 Ko) Télécharger le fichier
hal-01277625 , version 1 (22-02-2016)
hal-01277625 , version 2 (04-01-2017)
Nauman Shahid, Nathanael Perraudin, Gilles Puy, Pierre Vandergheynst. Compressive PCA for Low-Rank Matrices on Graphs. IEEE Transactions on Signal and Information Processing over Networks, 2016, pp.17. ⟨10.1109/TSIPN.2016.2631890⟩. ⟨hal-01277625v2⟩
292 Consultations
295 Téléchargements
