Proving Reachability-Logic Formulas Incrementally
Reachability Logic (RL) is a formalism for defining the operational semantics of programming languages and for specifying program properties. As a program logic it can be seen as a language-independent alternative to Hoare Logics. Several verification techniques have been proposed for RL, all of which have a circular nature: the RL formula under proof can circularly be used as a hypothesis in the proof of another RL formula, or even in its own proof. This feature is essential for dealing with possibly unbounded repetitive behaviour (e.g., program loops). The downside of such approaches is that the verification of a set of RL formulas is monolithic, i.e., either all formulas in the set are proved valid, or nothing can be inferred about any of the formula's validity or invalidity. In this paper we propose a new, incremental method for proving a large class of RL formulas. The proposed method takes as input a given RL formula under proof (corresponding to a given program fragment), together with a (possibly empty) set of other valid RL formulas (e.g., already proved using our method), which specify sub-programs of the program fragment under verification. It then checks certain conditions are shown to be equivalent to the validity of the RL formula under proof. A newly proved formula can then be incrementally used in the proof of other RL formulas, corresponding to larger program fragments. The process is repeated until the whole program is proved. We illustrate our approach by verifying the nontrivial Knuth-Morris-Pratt string-matching program.
