Why MAC Address Randomization is not Enough: An Analysis of Wi-Fi Network Discovery Mechanisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present several novel techniques to track (unassociated) mobile devices by abusing features of the Wi-Fi standard. This shows that using random MAC addresses, on its own, does not guarantee privacy. First, we show that information elements in probe requests can be used to fingerprint devices. We then combine these fingerprints with incremental sequence numbers, to create a tracking algorithm that does not rely on unique identifiers such as MAC addresses. Based on real-world datasets, we demonstrate that our algorithm can correctly track as much as 50% of devices for at least 20 minutes. We also show that commodity Wi-Fi devices use predictable scrambler seeds. These can be used to improve the performance of our tracking algorithm. Finally, we present two attacks that reveal the real MAC address of a device, even if MAC address randomization is used. In the first one, we create fake hotspots to induce clients to connect using their real MAC address. The second technique relies on the new 802.11u standard, commonly referred to as Hotspot 2.0, where we show that Linux and Windows send Access Network Query Protocol (ANQP) requests using their real MAC address.
asiaccs2016.pdf (483.18 Ko) Télécharger le fichier
hal-01282900 , version 1 (10-06-2016)
Mathy Vanhoef, Célestin Matte, Mathieu Cunche, Leonardo Cardoso, Frank Piessens. Why MAC Address Randomization is not Enough: An Analysis of Wi-Fi Network Discovery Mechanisms. ACM AsiaCCS, May 2016, Xi'an, China. ⟨10.1145/2897845.2897883⟩. ⟨hal-01282900⟩
2317 Consultations
7954 Téléchargements
