1IECL - Institut Élie Cartan de Lorraine (Université de Lorraine, Boulevard des Aiguillettes BP 70239 54506 Vandoeuvre-les-Nancy Cedex
Ile du Saulcy - 57 045 Metz Cedex 01 - France)
Abstract : We prove a uniqueness result for Nevanlinna functions. and this result is then used to give an elementary proof of the uniqueness in the inverse scattering problem for the Helmholtz equation on the line.
