Combinatorial RNA Design: Designability and Structure-Approximating Algorithm in Watson-Crick and Nussinov-Jacobson Energy Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2017
We consider the Combinatorial RNA Design problem, a minimal instance of RNA design where one must produce an RNA sequence that adopts a given secondary structure as its minimal free-energy structure. We consider two free-energy models where the contributions of base pairs are additive and independent: the purely combinatorial Watson-Crick model, which only allows equally-contributing A − U and C − G base pairs, and the real-valued Nussinov-Jacobson model, which associates arbitrary energies to A − U, C − G and G − U base pairs. We first provide a complete characterization of designable structures using restricted alphabets and, in the four-letter alphabet, provide a complete characterization for designable structures without unpaired bases. When unpaired bases are allowed, we characterize extensive classes of (non-)designable structures, and prove the closure of the set of designable structures under the stutter operation. Membership of a given structure to any of the classes can be tested in Θ(n) time, including the generation of a solution sequence for positive instances. Finally, we consider a structure-approximating relaxation of the design, and provide a Θ(n) algorithm which, given a structure S that avoids two trivially non-designable motifs, transforms S into a designable structure constructively by adding at most one base-pair to each of its stems.
CombinatorialRNADesign-Hales-Manuch-Ponty-Stacho-Algorithmica-2015.pdf (530.18 Ko) Télécharger le fichier
hal-01285499 , version 1 (09-03-2016)
hal-01285499 , version 2 (01-08-2016)
Paternité
Jozef Haleš, Alice Héliou, Ján Maňuch, Yann Ponty, Ladislav Stacho. Combinatorial RNA Design: Designability and Structure-Approximating Algorithm in Watson-Crick and Nussinov-Jacobson Energy Models. Algorithmica, 2017, 79 (3), pp.835--856. ⟨10.1007/s00453-016-0196-x⟩. ⟨hal-01285499v2⟩
656 Consultations
344 Téléchargements
