Exponential Stability of Compactly Coupled Wave Equations with Delay Terms in the Boundary Feedbacks
We consider a linear system of compactly coupled wave equations with Neumann feedback controllers that contain delay terms. First, we prove under some assumptions that the closed-loop system generates a $$C_{0}-$$semigroup of contractions on an appropriate Hilbert space. Then, under further assumptions, we show that the closed-loop system is exponentially stable. This result is obtained by introducing a suitable energy function and by using an observability estimate.
Informatique [cs]
