Representation and Analysis of Piecewise Linear Functions in Abs-Normal Form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It follows from the well known min/max representation given by Scholtes in his recent Springer book, that all piecewise linear continuous functions $$y = F(x) : \mathbb {R}^n \rightarrow \mathbb {R}^m$$ can be written in a so-called abs-normal form. This means in particular, that all nonsmoothness is encapsulated in $$s$$ absolute value functions that are applied to intermediate switching variables $$z_i$$ for $$i=1, \ldots ,s$$ . The relation between the vectors $$x, z$$ , and $$y$$ is described by four matrices $$Y, L, J$$ , and $$Z$$ , such that $$ \left[ \begin{array}{c} z \\ y \end{array}\right] = \left[ \begin{array}{c} c \\ b \end{array}\right] + \left[ \begin{array}{cc} Z &{} L \\ J &{} Y \end{array}\right] \left[ \begin{array}{c} x \\ |z |\end{array}\right] $$ This form can be generated by ADOL-C or other automatic differentation tools. Here $$L$$ is a strictly lower triangular matrix, and therefore $$ z_i$$ can be computed successively from previous results. We show that in the square case $$n=m$$ the system of equations $$F(x) = 0$$ can be rewritten in terms of the variable vector $$z$$ as a linear complementarity problem (LCP). The transformation itself and the properties of the LCP depend on the Schur complement $$S = L - Z J^{-1} Y$$ .
978-3-662-45504-3_32_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01286443 , version 1 (10-03-2016)
Paternité
Tom Streubel, Andreas Griewank, Manuel Radons, Jens-Uwe Bernt. Representation and Analysis of Piecewise Linear Functions in Abs-Normal Form. 26th Conference on System Modeling and Optimization (CSMO), Sep 2013, Klagenfurt, Austria. pp.327-336, ⟨10.1007/978-3-662-45504-3_32⟩. ⟨hal-01286443⟩
131 Consultations
1169 Téléchargements
