Microcities: a Platform based on Microclouds for Neighborhood Services
The current mobile Cloud computing trend has set the focus on the ubiquity of computation.
However, the current architecture confines the cloud to datacenters, which are generally
far from the user. Distance leads to increased utilization of the broadband Wide Area Network
- WAN - and poor user experience, especially for interactive applications. Decentralized architectures
are emerging as an alternative, but they still fail to adapt to situations where files are
concurrently modified. A semi-decentralized approach which confines local traffic close to the user
while still maintaining centralized characteristics, running on the users and network devices, can
provide a better Quality of Experience (QoE) in large urban populations in mobile cloud networks.
In this report, we propose a novel semi-centralized cloud architecture based on microclouds. Microclouds
are dynamically created and allow users to contribute resources from their computers,
mobile and network devices to the cloud. We present the process for building and reconfiguring the
microclouds, whilst guaranteeing a high QoE to users of real-time applications. We also provide a
description of a realistic mobile cloud use-case. Results from a simulation-based evaluation indicate
that the microclouds architecture is able to sustain hundreds of mobile devices and provide a
latency significantly lower than regular Clouds based on datacenters.
La tendance actuelle des applications mobiles dans les nuages
informatiques (clouds) a mis láccent sur lómniprésence du calcul. Cependant,
lárchitecture actuelle confine le cloud dans les centres de données qui sont
généralement loin de lútilisateur. Cette distance conduit á une utilisation accrue
de la bande passante des réseaux longue distance (Wide Area Network -WAN) et
conduit á une expérience utilisateur médiocre, en particulier pour les applications
interactives. Les architectures décentralisées apparaissent comme une alternative,
mais elles ne parviennent pas toujours á s’adapter á des situations oú les fichiers
sont modifiés de maniére concurrente. Une approche semi-décentralisée, mise en
oeuvre sur les équipements des utilisateurs et du réseau et confinant le trafic local
á proximité de lútilisateur tout en conservant les caractéristiques centralisées,
peut fournir une meilleure qualité déxpérience (QoE) aux grandes populations
urbaines utilisant les applications mobiles des clouds. Dans cet rapport, nous
proposons une nouvelle architecture de cloud semi-centralisée fondée sur les
"microclouds". Les microclouds sont créés dynamiquement et permettent aux
utilisateurs de fournir au cloud des ressources de leurs ordinateurs, smartphones
et équipements réseau. Nous présentons le processus de construction et de
reconfiguration des microclouds, tout en garantissant un haut degré de QoE aux
utilisateurs dápplications temps-réel. Nous donnons également une description
dún cas d'utilisation réaliste de cloud mobile. Les résultats dúne évaluation
menée par simulation indiquent que lárchitecture á base de microclouds est en
mesure de gérer des centaines d'équipements mobiles et de fournir un temps de
latence nettement inférieur á celui des clouds traditionnels fondés sur les centres
de données.
