A bilinear input-output model with state-dependent delay for separated flow control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— It is proposed a first step to the model-based closed-loop control of a separated flow. In such situations, fluid mechanics phenomena are highly nonlinear and can be represented by means of the Navier-Stokes equations. However, such a model still rises difficult issues for control practice. This paper proposes an alternative, bilinear and delayed model, the accuracy of which is studied. The identification technique combines least-square technique with a Mesh Adaptive Direct Search (MADS) algorithm. The main feature of the model is state dependent structure of input delay.
Automatique
ECC16_0448_FI.pdf (679.85 Ko) Télécharger le fichier
hal-01298166 , version 1 (05-04-2016)
  • HAL Id : hal-01298166 , version 1
Maxime Feingesicht, Cédric Raibaudo, Andrey Polyakov, Franck Kerherve, Jean-Pierre Richard. A bilinear input-output model with state-dependent delay for separated flow control. European Control Conference 2016, Jun 2016, Aalborg, Denmark. ⟨hal-01298166⟩
206 Consultations
309 Téléchargements
