A posteriori error estimates for non conforming approximation of quasi Stokes problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2013
We derive and analyze an a posteriori error estimator for nonconforming finite element approximation for the quasi-Stokes problem, which is based on the solution of local problem on stars with low cost computation, this indicator is equivalent to the energy error norm up to data oscillation, neither saturation assumption nor comparison with residual estimator are made.
Vol.16.pp.47-66.pdf (3.11 Mo) Télécharger le fichier
hal-01299520 , version 1 (07-04-2016)
B. Achchab, A. Agouzal, K. Bouihat. A posteriori error estimates for non conforming approximation of quasi Stokes problem. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2013, Volume 16, 2012, pp.47-66. ⟨10.46298/arima.1963⟩. ⟨hal-01299520⟩
107 Consultations
691 Téléchargements
