A Survey of Positioning Techniques and Location Based Services in Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Positioning techniques are known in a wide variety of wireless radio access technologies. Traditionally, Global Positioning System (GPS) is the most popular outdoor positioning system. Localization also exists in mobile networks such as Global System for Mobile communications (GSM). Recently, Wireless Local Area Networks (WLAN) become widely deployed, and they are also used for localizing wireless-enabled clients. Many techniques are used to estimate client position in a wireless network. They are based on the characteristics of the received wireless signals: power, time or angle of arrival. In addition, hybrid positioning techniques make use of the collaboration between different wireless radio access technologies existing in the same geographical area. Client positioning allows the introduction of numerous services like real-time tracking, security alerts, informational services and entertainment applications. Such services are known as Location Based Services (LBS), and they are useful in both commerce and security sectors. In this paper, we explain the principles behind positioning techniques used in satellite networks, mobile networks and Wireless Local Area Networks. We also describe hybrid localization methods that exploit the coexistence of several radio access technologies in the same region, and we classify the location based services into several categories. When localization accuracy is improved, position-dependant services become more robust and efficient, and user satisfaction increases.
A_Survey_of_Positioning_Techniques_and_Location_Based_Services_in_Wireless_Networks.pdf (272.5 Ko) Télécharger le fichier
hal-01310662 , version 1 (03-05-2016)
Mohamad Yassin, Elias Rachid. A Survey of Positioning Techniques and Location Based Services in Wireless Networks. IEEE 2015 Int. Conf. Signal Processing, Informatics, Communication and Energy Systems, Feb 2015, Kozhikode, India. ⟨10.1109/SPICES.2015.7091420⟩. ⟨hal-01310662⟩
338 Consultations
2961 Téléchargements
