Abstract : Analytic combinatorics studies the asymptotic behaviour of sequences through
the analytic properties of their generating functions. This article provides
effective algorithms required for the study of analytic combinatorics in
several variables, together with their complexity analyses. Given a
multivariate rational function we show how to compute its smooth isolated
critical points, with respect to a polynomial map encoding asymptotic
behaviour, in complexity singly exponential in the degree of its denominator.
We introduce a numerical Kronecker representation for solutions of polynomial
systems with rational coefficients and show that it can be used to decide
several properties (0 coordinate, equal coordinates, sign conditions for real
solutions, and vanishing of a polynomial) in good bit complexity. Among the
critical points, those that are minimal---a property governed by inequalities
on the moduli of the coordinates---typically determine the dominant asymptotics
of the diagonal coefficient sequence. When the Taylor expansion at the origin
has all non-negative coefficients (known as the `combinatorial case') and under
regularity conditions, we utilize this Kronecker representation to determine
probabilistically the minimal critical points in complexity singly exponential
in the degree of the denominator, with good control over the exponent in the
bit complexity estimate. Generically in the combinatorial case, this allows one
to automatically and rigorously determine asymptotics for the diagonal
coefficient sequence. Examples obtained with a preliminary implementation show
the wide applicability of this approach.
