A Supervised Approach for Rhythm Transcription Based on Tree Series Enumeration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a rhythm transcription system integrated in the computer-assisted composition environment OpenMusic. Rhythm transcription consists in translating a series of dated events into traditional music notation's pulsed and structured representation. As transcription is equivocal, our system favors interactions with the user to reach a satisfactory compromise between various criteria, in particular the precision of the transcription and the readability of the output score. It is based on a uniform approach, using a hierarchical representation of duration notation in the form of rhythm trees, and an efficient dynamic-programming algorithm that lazily evaluates the transcription solutions. It is run through a dedicated user interface allowing to interactively explore the solution set, visualize the solutions and locally edit them.
Quant16-RR.pdf (1.38 Mo) Télécharger le fichier
hal-01315689 , version 1 (13-05-2016)
hal-01315689 , version 2 (17-05-2016)
Paternité
  • HAL Id : hal-01315689 , version 2
Adrien Ycart, Florent Jacquemard, Jean Bresson, Slawomir Staworko. A Supervised Approach for Rhythm Transcription Based on Tree Series Enumeration. International Computer Music Conference (ICMC), Sep 2016, Utrecht, Netherlands. ⟨hal-01315689v2⟩
1295 Consultations
2498 Téléchargements
