Sorting Signed Circular Permutations by Super Short Reversals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of sorting a circular permutation by reversals of length at most 2, a problem that finds application in comparative genomics. Polynomial-time solutions for the unsigned version of this problem are known, but the signed version remained open. In this paper, we present the first polynomial-time solution for the signed version of this problem. Moreover, we perform an experiment for inferring distances and phylogenies for published Yersinia genomes and compare the results with the phylogenies presented in previous works.
SortingSignedCircularPermutationsBySuperShortReversals_author_version.pdf (332.74 Ko) Télécharger le fichier
hal-01316993 , version 1 (12-06-2017)
Gustavo R Galvão, Christian Baudet, Zanoni Dias. Sorting Signed Circular Permutations by Super Short Reversals. 11th International Symposium on Bioinformatics Research and Applications, Jun 2015, Norfolk, Virginia, United States. pp.272-283, ⟨10.1007/978-3-319-19048-8_23⟩. ⟨hal-01316993⟩
138 Consultations
155 Téléchargements
