Abstract : The Unified Model (UM) is a model produced by the UK MetOffice for Numerical Weather Prediction (NWP) and climate simulation. It is used extensively by various university, government and other research organizations on the large supercomputer hosted at the National Computing Infrastructure (NCI). A 3-year collaboration between NCI, the Australian Bureau of Meteorology and Fujitsu is underway to address performance and scalability issues in the UM on NCI’s supercomputer, Raijin.IO performance in the UM is the most dominant factor in its overall performance. The IO server approach employed is sophisticated and requires proper calibration to achieve acceptable performance. Global synchronization and file lock contention is a problem that can be remedied with simple MPI global collective calls. Complimentary IO strategies, such as MPI-IO and directed IO, are being investigated for implementation.The OpenMP implementation employed in the UM is investigated, and is found to have inefficiencies that are detrimental to the load balance of the model. Only loop-wise parallelism is employed. Due to the inherently imbalanced nature of the model, a task-wise approach could yield improved threading efficiency.
Ralf Denzer; Robert M. Argent; Gerald Schimak; Jiří Hřebíček. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. Springer, IFIP Advances in Information and Communication Technology, AICT-448, pp.552-560, 2015, Environmental Software Systems. Infrastructures, Services and Applications. 〈10.1007/978-3-319-15994-2_56〉
https://hal.inria.fr/hal-01328606
Contributeur : Hal Ifip
Soumis le : mercredi 8 juin 2016 - 11:22:22
Dernière modification le : mercredi 8 juin 2016 - 11:34:29
Dale Roberts, Mark Cheeseman. A Performance Assessment of the Unified Model. Ralf Denzer; Robert M. Argent; Gerald Schimak; Jiří Hřebíček. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. Springer, IFIP Advances in Information and Communication Technology, AICT-448, pp.552-560, 2015, Environmental Software Systems. Infrastructures, Services and Applications. 〈10.1007/978-3-319-15994-2_56〉. 〈hal-01328606〉
