DEMO: Panoptiphone: How Unique is Your Wi-Fi Device? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
MAC address randomization in Wi-Fi-enabled devices has recently been adopted to prevent passive tracking of mobile devices. However, Wi-Fi frames still contain fields that can be used to fingerprint devices and potentially allow tracking. Panoptiphone is a tool inspired by the web browser fingerprinting tool Panopticlick, which aims to show the identifying information that can be found in the frames broadcast by a Wi-Fi-enabled device. Information is passively collected from devices that have their Wi-Fi interface enabled, even if they are not connected to an access point. Panoptiphone uses this information to create a fingerprint of the device and empirically evaluate its uniqueness among a database of fingerprints. The user is then shown how much identifying information its device is leaking through Wi-Fi and how unique it is.
paper.pdf (272.71 Ko) Télécharger le fichier
hal-01330479 , version 1 (11-11-2016)
Célestin Matte, Mathieu Cunche. DEMO: Panoptiphone: How Unique is Your Wi-Fi Device?. ACM WiSec 2016, Jul 2016, Darmstadt, Germany. ⟨10.1145/2939918.2942417⟩. ⟨hal-01330479⟩
371 Consultations
725 Téléchargements
