APISENSE®: Mobile crowd-sensing made easy! - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2016
APISENSE® (http://apisense.io) is a crowd-sensing platform that leverages the gathering of field datasets at scale. In particular, APISENSE® is designed as a Software-as-a-Service (SaaS) solution that remotely orchestrates crowds of mobile devices to monitor physical events or human behaviours in the wild. Collecting data in the field tends to be a tedious tasks for most of researchers as it requires to spend time, energy and money to develop dedicated mobile apps. The role of APISENSE® is therefore to catalyse this process by delivering to the scientific community a comprehensive distributed infrastructure that guarantee both privacy and energy consumption of participants. The applications of APISENSE® encompasses case studies in the domains of telecom, smart cities, air quality, or human sciences.
ECAAS-APISENSE.pdf (15.48 Mo) Télécharger le fichier
hal-01332594 , version 1 (13-10-2016)
  • HAL Id : hal-01332594 , version 1
Romain Rouvoy. APISENSE®: Mobile crowd-sensing made easy!. 2016. ⟨hal-01332594⟩
251 Consultations
55 Téléchargements
