Effective padding of multidimensional arrays to avoid cache conflict misses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Caches are used to significantly improve performance. Even with high degrees of set associativity, the number of accessed data elements mapping to the same set in a cache can easily exceed the degree of associativity. This can cause conflict misses and lower performance, even if the working set is much smaller than cache capacity. Array padding (increasing the size of array dimensions) is a well-known optimization technique that can reduce conflict misses. In this paper, we develop the first algorithms for optimal padding of arrays aimed at a set-associative cache for arbitrary tile sizes. In addition, we develop the first solution to padding for nested tiles and multi-level caches. Experimental results with multiple benchmarks demonstrate a significant performance improvement from padding.
Fichier non déposé
hal-01335346 , version 1 (21-06-2016)
  • HAL Id : hal-01335346 , version 1
Changwan Hong, Wenlei Bao, Albert Cohen, Sriram Krishnamoorthy, Louis-Noël Pouchet, et al.. Effective padding of multidimensional arrays to avoid cache conflict misses. PLDI 2016: Proceedings of the 37th ACM SIGPLAN Conference on Programming Language Design and Implementation, Jun 2016, Santa Barbara, United States. ⟨hal-01335346⟩
291 Consultations
0 Téléchargements
