A Modular Formalization of Reversibility for Concurrent Models and Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Causal-consistent reversibility is the reference notion of reversibility for concurrency. We introduce a modular framework for defining causal-consistent reversible extensions of concurrent models and languages. We show how our framework can be used to define reversible extensions of formalisms as different as CCS and concurrent X-machines. The generality of the approach allows for the reuse of theories and techniques in different settings.
main.pdf (281.05 Ko) Télécharger le fichier
hal-01337423 , version 1 (26-06-2016)
  • HAL Id : hal-01337423 , version 1
Alexis Bernadet, Ivan Lanese. A Modular Formalization of Reversibility for Concurrent Models and Languages. ICE 2016, Jun 2016, Heraklion, Greece. ⟨hal-01337423⟩
84 Consultations
66 Téléchargements
