Psychophysical Power Optimization of Friction Modulation for Tactile Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ultrasonic vibration and electrovibration can modulate the friction between a surface and a sliding finger. The power consumption of these devices is critical to their integration in modern mobile devices such as smartphones. This paper presents a simple control solution to reduce up to 68.8% this power consumption by taking advantage of the human perception limits.
Thomas.pdf (591.2 Ko) Télécharger le fichier
hal-01342010 , version 1 (11-07-2016)
Thomas Sednaoui, Eric Vezzoli, David Gueorguiev, Cedrick Chappaz, Betty Lemaire-Semail. Psychophysical Power Optimization of Friction Modulation for Tactile Interfaces. Haptics: Perception, Devices, Control, and Applications, Jul 2016, London, United Kingdom. ⟨10.1007/978-3-319-42324-1_35⟩. ⟨hal-01342010⟩
410 Consultations
236 Téléchargements
