Investigation of the Tesla Transformer as a Device for One-Wire Power and Signaling and as a Device for Power and Signaling Through the Ground - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new method for power and communications through single wire or the ground as a medium is investigated. The focus of the research is based on the proper construction and operation of a Tesla Transformer, so as to be able to transmit power and/or signals through one wire or the ground. The conclusions are based upon experimental data. There are successful results for single wire power supply with efficiency of about 20%. There is room for improvement of the circuits, so better efficiency is expected. The utilization of the soil as a medium for currents propagation didn’t give any useful results. Due to its complex properties, the ground transmission requires lower working frequency, hence bigger and more complicated coils, special drive circuit and good grounding.
336594_1_En_49_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01343517 , version 1 (08-07-2016)
Paternité
Kaloyan Mihaylov, Rui Neves-Medeiros, Rumen Arnaudov, Stanimir Valtchev. Investigation of the Tesla Transformer as a Device for One-Wire Power and Signaling and as a Device for Power and Signaling Through the Ground. 6th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2015, Costa de Caparica, Portugal. pp.459-466, ⟨10.1007/978-3-319-16766-4_49⟩. ⟨hal-01343517⟩
93 Consultations
267 Téléchargements
