Abstract : Attribute-based credentials allow a user to prove properties about herself anonymously. Revoking such credentials, which requires singling them out, is hard because it is at odds with anonymity. All revocation schemes proposed to date either sacrifice anonymity altogether, require the parties to be online, or put high load on the user or the verifier. As a result, these schemes are either too complicated for low-powered devices like smart cards or they do not scale. We propose a new revocation scheme that has a very low computational cost for users and verifiers, and does not require users to process updates. We trade only a limited, but well-defined, amount of anonymity to make the first practical revocation scheme that is efficient at large scales and fast enough for smart cards.
https://hal.inria.fr/hal-01345136 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, July 13, 2016 - 11:10:30 AM Last modification on : Wednesday, July 13, 2016 - 11:18:41 AM
Wouter Lueks, Gergely Alpár, Jaap- Henk Hoepman, Pim Vullers. Fast Revocation of Attribute-Based Credentials for Both Users and Verifiers. 30th IFIP International Information Security Conference (SEC), May 2015, Hamburg, Germany. pp.463-478, ⟨10.1007/978-3-319-18467-8_31⟩. ⟨hal-01345136⟩
