Application of a Game Theoretic Approach in Smart Sensor Data Trustworthiness Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Konstantinos Maraslis
  • Fonction : Auteur
  • PersonId : 986207
Theodoros Spyridopoulos
  • Fonction : Auteur
  • PersonId : 986208
George Oikonomou
  • Fonction : Auteur
  • PersonId : 986209
Theo Tryfonas
  • Fonction : Auteur
  • PersonId : 986210
Mo Haghighi
  • Fonction : Auteur
  • PersonId : 986211
In this work we present an Intrusion Detection (ID) and an Intrusion Prevention (IP) model for Wireless Sensor Networks (WSNs). The attacker’s goal is to compromise the deployment by causing nodes to report faulty sensory information. The defender, who is the WSN’s operator, aims to detect the presence of faulty sensor measurements (ID) and to subsequently recover compromised nodes (IP). In order to address the conflicting interests involved, we adopt a Game Theoretic approach that takes into consideration the strategies of both players and we attempt to identify the presence of Nash Equilibria in the two games. The results are then verified in two simulation contexts: Firstly, we evaluate the model in a middleware-based WSN which uses clustering over a bespoke network stack. Subsequently, we test the model in a simulated IPv6-based sensor deployment. According to the findings, the results of both simulation models confirm the results of the theoretic one.
337885_1_En_40_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01345151 , version 1 (13-07-2016)
Paternité
Konstantinos Maraslis, Theodoros Spyridopoulos, George Oikonomou, Theo Tryfonas, Mo Haghighi. Application of a Game Theoretic Approach in Smart Sensor Data Trustworthiness Problems. 30th IFIP International Information Security Conference (SEC), May 2015, Hamburg, Germany. pp.601-615, ⟨10.1007/978-3-319-18467-8_40⟩. ⟨hal-01345151⟩
54 Consultations
162 Téléchargements
