Conference papers
Particle Swarm Optimization Algorithm Establish the Model of Tobacco Ingredients in Near Infrared Spectroscopy Quantitative Analysis
Abstract : 57 tobacco samples were chosen, the near-infrared diffuse reflectance spectra at five different parts of tobacco leafs were averaged as the original spectra, the range of 4000-9000 wavenumber of spectral information was selected after wavelength selection, first-order differential was used to eliminate the impact of offset, PCA was used to reduce the dimensions and select the most representative of the principal components of the sample information. After these, use PSO and the data of chemical composition of nicotine and total nitrogen, to establish the models of near-infrared spectra of the main ingredient in tobacco quantitative analysis. In which, nicotine and total nitrogen quantitative analysis of modeling set correlation coefficients were 0.8886,0.9290; the prediction set correlation coefficients were 0.8786,0.8487. RMSEC values were 0.4737,0.2215; RMSEP values were 0.6417,0.2677. The results show that: PSO can be used to establish the model of nicotine and total nitrogen by near infrared spectroscopy quantitative analysis in tobacco.
Document type :
Conference papers
Complete list of metadata
Cited literature [3 references]  Display  Hide  Download
https://hal.inria.fr/hal-01348219
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, July 22, 2016 - 3:49:11 PM
Last modification on : Friday, July 22, 2016 - 4:04:43 PM
Long-term archiving on: : Sunday, October 23, 2016 - 1:50:03 PM
File
978-3-642-36137-1_12_Chapter.p...
Identifiers
Citation
Bibo Ma, Haiyan Ji. Particle Swarm Optimization Algorithm Establish the Model of Tobacco Ingredients in Near Infrared Spectroscopy Quantitative Analysis. 6th Computer and Computing Technologies in Agriculture (CCTA), Oct 2012, Zhangjiajie, China. pp.92-98, ⟨10.1007/978-3-642-36137-1_12⟩. ⟨hal-01348219⟩
Share
Metrics
Record views
27
Files downloads
59
