Spatial Optimization and Mode Analysis of Primary Industry Structure in Yellow River Delta - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the support of the total output of primary industry, secondary industry and tertiary industry and industry value of cultivating industry, forestry industry, animal husbandry industry and fishery industry of 19 country-level units in Yellow River Delta in 2007, the paper calculated the variation index of economic development based on country level, the MDS analysis was explored for primary industry, secondary industry and tertiary industry and compared with spatial difference characteristics of 19 country-level units in Yellow River Delta. The study carried out the analysis of combination analysis of primary, secondary and tertiary industry, and optimized the cultivating industry, forestry, animal husbandry and fishery industry. Autocorrelation characteristics was clarified by Moran‘s I calculation, the new development mode of agricultural industrial structure was systemically concluded that the different mode presented in the different country units. The results showed that the industry evolution stage of primary, secondary and tertiary industry structure of 19 country units is in "secondary, primary and tertiary industries " stage and " secondary, primary and tertiary industries " stage according to industry structure stages theory, the obvious characteristics is that the cultivating industry value has spatial variability based on classical statistics combinig with universal Kriging. The emphasis of industry adjustment should be the focus on the secondary industry driving transformation into the primary, secondary and tertiary industries jointly driving economic growth, straight-pushing mode and tilting mode were put forward to new ideas about promoting industrial optimization and coordination development in Yellow River Delta. The study drew a conclusion that the measures were took to optimize industrial structure of cultivating industry, forestry industry, animal husbandry and fishery industry by combing straight-pushing mode with tilting mode, during the coordination development, focused on association effects of land and marine industry, extended agriculture industrialization chain and formed the diversification mode.
978-3-642-36137-1_19_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01348227 , version 1 (22-07-2016)
Paternité
Ping Yang, Yujian Yang. Spatial Optimization and Mode Analysis of Primary Industry Structure in Yellow River Delta. 6th Computer and Computing Technologies in Agriculture (CCTA), Oct 2012, Zhangjiajie, China. pp.150-160, ⟨10.1007/978-3-642-36137-1_19⟩. ⟨hal-01348227⟩
56 Consultations
68 Téléchargements
