Multi-region two-stream R-CNN for action detection
Xiaojiang Peng 1 Cordelia Schmid 1
1 Thoth - Apprentissage de modèles à partir de données massives
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann
Abstract : We propose a multi-region two-stream R-CNN model for action detection in realistic videos. We start from frame-level action detection based on faster R-CNN [1], and make three contributions: (1) we show that a motion region proposal network generates high-quality proposals , which are complementary to those of an appearance region proposal network; (2) we show that stacking optical flow over several frames significantly improves frame-level action detection; and (3) we embed a multi-region scheme in the faster R-CNN model, which adds complementary information on body parts. We then link frame-level detections with the Viterbi algorithm, and temporally localize an action with the maximum subarray method. Experimental results on the UCF-Sports, J-HMDB and UCF101 action detection datasets show that our approach outperforms the state of the art with a significant margin in both frame-mAP and video-mAP.
Type de document :
Communication dans un congrès
ECCV - European Conference on Computer Vision, Oct 2016, Amsterdam, Netherlands. Springer, 9908, pp.744-759, 2016, Lecture Notes in Computer Science. 〈10.1007/978-3-319-46493-0_45〉
Liste complète des métadonnées
Littérature citée [43 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01349107
Contributeur : Thoth Team <>
Soumis le : jeudi 5 janvier 2017 - 15:50:22
Dernière modification le : mercredi 11 avril 2018 - 01:57:58
Fichier
eccv16-pxj-v3.pdf
Fichiers produits par l'(les) auteur(s)
Collections
Citation
Xiaojiang Peng, Cordelia Schmid. Multi-region two-stream R-CNN for action detection. ECCV - European Conference on Computer Vision, Oct 2016, Amsterdam, Netherlands. Springer, 9908, pp.744-759, 2016, Lecture Notes in Computer Science. 〈10.1007/978-3-319-46493-0_45〉. 〈hal-01349107v3〉
Métriques
Consultations de la notice
3062
Téléchargements de fichiers
2070
