Weakly-Supervised Semantic Segmentation using Motion Cues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fully convolutional neural networks (FCNNs) trained on a large number of images with strong pixel-level annotations have become the new state of the art for the semantic segmentation task. While there have been recent attempts to learn FCNNs from image-level weak annotations , they need additional constraints, such as the size of an object , to obtain reasonable performance. To address this issue, we present motion-CNN (M-CNN), a novel FCNN framework which incorporates motion cues and is learned from video-level weak annotations. Our learning scheme to train the network uses motion segments as soft constraints, thereby handling noisy motion information. When trained on weakly-annotated videos, our method outperforms the state-of-the-art approach on the PASCAL VOC 2012 image segmentation benchmark. We also demonstrate that the performance of M-CNN learned with 150 weak video annotations is on par with state-of-the-art weakly-supervised methods trained with thousands of images. Finally, M-CNN substantially out-performs recent approaches in a related task of video co-localization on the YouTube-Objects dataset.
mcnn.pdf (1.25 Mo) Télécharger le fichier
hal-01292794 , version 1 (23-03-2016)
hal-01292794 , version 2 (28-07-2016)
hal-01292794 , version 3 (02-08-2016)
Pavel Tokmakov, Karteek Alahari, Cordelia Schmid. Weakly-Supervised Semantic Segmentation using Motion Cues. ECCV - European Conference on Computer Vision, Oct 2016, Amsterdam, Netherlands. pp.388-404, ⟨10.1007/978-3-319-46493-0_24⟩. ⟨hal-01292794v3⟩
1774 Consultations
1863 Téléchargements
