Design of Labour Agency Platform Based on Agent Technology of JADE
Ordinary labour agency system provides services for clients with a data center which comprises single or multi servers according to the scale. And each server provides service of regular function. Therefore problems in security, load balance and extendibility may be involved. In this paper, a labour agency platform using an agent technology called JADE was designed, which effectively solved the problem of normal systems.
Informatique [cs]
