1NECS - Networked Controlled Systems (Centre de Recherche Inria
655 Avenue de l'Europe,
38330 Montbonnot-Saint-Martin
GIPSA-labGIPSA-lab,
11 rue des Mathématiques,
Grenoble Campus BP46,
F-38402 SAINT MARTIN D'HERES CEDEX - France)
Abstract : This paper describes the development of a reduced-order linear mathematical model of a hydroelectric unit subject to pressure perturbations in the draft tube of the hydraulic turbine, as it is the case at off-design operation (partial load or full load). The objective behind this development is to design a control algorithm able to attenuate the effect of these hydraulic pressure oscillations on the hydroelectric unit. First, we develop the reduced-order linear hydraulic model of the turbine and the pipes. Then this hydraulic model is combined with a reduced order model of a single machine infinite bus (SMIB) system. Finally we present simulation results of a controller designed with this model.
Simon Gerwig, Bilal Sari, Federica Garin, Carlos Canudas de Wit. Reduced model for control in a hydroelectric unit at off-design operation. 15th European Control Conference (ECC 2016), Jun 2016, Aalborg, Denmark. pp.2096-2101. ⟨hal-01354358⟩
