Journal articles
Solving k-Set Agreement Using Failure Detectors in Unknown Dynamic Networks
Abstract : The failure detector abstraction has been used to solve agreement problems in asynchronous systems prone to crash failures, but so far it has mostly been used in static and complete networks. This paper aims to adapt existing failure detectors in order to solve agreement problems in unknown, dynamic systems. We are specifically interested in the k-set agreement problem. The problem of k-set agreement is a generalization of consensus where processes can decide up to k different values. Although some solutions to this problem have been proposed in dynamic networks, they rely on communication synchrony or make strong assumptions on the number of process failures. In this paper we consider unknown dynamic systems modeled using the formalism of Time-Varying Graphs, and extend the definition of the existing ΠΣx,y failure detector to obtain the ΠΣ ⊥,x,y failure detector, which is sufficient to solve k-set agreement in our model. We then provide an implementation of this new failure detector using connectivity and message pattern assumptions. Finally, we present an algorithm using ΠΣ ⊥,x,y to solve k-set agreement.
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01354864
Contributor : Pierre Sens Connect in order to contact the contributor
Submitted on : Friday, August 19, 2016 - 5:45:27 PM
Last modification on : Tuesday, March 22, 2022 - 11:10:10 AM
Long-term archiving on: : Sunday, November 20, 2016 - 10:47:08 AM
File
tpds.pdf
Identifiers
  • HAL Id : hal-01354864, version 1
Citation
Denis Jeanneau, Thibault Rieutord, Luciana Arantes, Pierre Sens. Solving k-Set Agreement Using Failure Detectors in Unknown Dynamic Networks. IEEE Transactions on Parallel and Distributed Systems, Institute of Electrical and Electronics Engineers, 2016. ⟨hal-01354864⟩
Share
Metrics
Record views
194
Files downloads
189
