Self-adaptation in software-intensive cyber–physical systems: From system goals to architecture configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Systems and Software Année : 2016
Design of self-adaptive software-intensive Cyber-Physical Systems (siCPS) operating in dynamic environments is a significant challenge when a sufficient level of dependability is required. This stems partly from the fact that the concerns of self-adaptivity and dependability are to an extent contradictory. In this paper, we introduce IRM-SA (Invariant Refinement Method for Self-Adaptation) – a design method and associated formally grounded model targeting siCPS – that addresses self-adaptivity and supports dependability by providing traceability between system requirements, distinct situations in the environment, and predefined configurations of system architecture. Additionally, IRM-SA allows for architecture self-adaptation at runtime and integrates the mechanism of predictive monitoring that deals with operational uncertainty. As a proof of concept, it was implemented in DEECo, a component framework that is based on dynamic ensembles of components. Furthermore, its feasibility was evaluated in experimental settings assuming decentralized system operation.
2016-JSS-IRM-SA.pdf (1.34 Mo) Télécharger le fichier
hal-01355034 , version 1 (22-08-2016)
Ilias Gerostathopoulos, Tomas Bures, Petr Hnetynka, Jaroslav Keznikl, Michal Kit, et al.. Self-adaptation in software-intensive cyber–physical systems: From system goals to architecture configurations. Journal of Systems and Software, 2016, ⟨10.1016/j.jss.2016.02.028⟩. ⟨hal-01355034⟩
252 Consultations
453 Téléchargements
