KPASSA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2014
KPASSA
This software is dedicated to the simulation, analysis, and static scheduling of Event/Marked Graphs, SDF and KRG extensions. A graphical interface allows to edit the Process Networks and their time annotations (latency, ...). Symbolic simulation and graph-theoretic analysis methods allow to compute and optimize static schedules, with best throughputs and minimal buffer sizes. In the case of KRG the (ultimately k-periodic) routing patterns can also be provided and transformed for optimal combination of switching and scheduling when channels are shared. KPASSA also allows for import/export of specific description formats such as UML-MARTE, to and from our other TimeSquare tool.
Fichier non déposé
hal-01355713 , version 1 (24-08-2016)
  • HAL Id : hal-01355713 , version 1
Jean-Vivien Millo. KPASSA. France, Patent n° : IDDN.FR.001.350040.000.S.P.2014.000.10600. 2014. ⟨hal-01355713⟩
76 Consultations
0 Téléchargements
