Sports Tournament Predictions Using Direct Manipulation
An advanced interface for sports tournament predictions uses direct manipulation to allow users to make nonlinear predictions. Unlike previous interface designs, this proposed technique better matches the way people actually make predictions, such as first choosing the winner and then filling up the rest of the bracket.
Interface homme-machine [cs.HC]
cga16-sports-tournament-predictions-using-direct-manipulation.pdf (2.94 Mo)
Télécharger le fichier
