Conference papers
Evaluation of Temporal Resolution Effect in Remote Sensing Based Crop Phenology Detection Studies
Abstract : Remote sensing based phenology detection method has been employed to study agriculture, forestry and other vegetations for its potential to reflect the variations in climate change. These studies usually utilized time series Normalized Difference Vegetation Index (NDVI) generated from various sensors through a Maximum Value Compositing (MVC) process, which minimized the contamination from cloud and simultaneously introduce degradation of temporal accuracy. In this study, we assess the impact of temporal resolution on crop phenology derivation researches by comparing three different Moderate Resolution Imaging Spectroradiometer (MODIS) datasets: daily surface reflectance, 8 day composited surface reflectance and 16 day composited NDVI. The surface reflectance data were first filtered by employing auxiliary data which contained quality and viewing geometry information, and then used to calculate NDVI with specific date. A least square method was taken to fit the survival data points to double logistic function. And finally, seven time-related metrics were obtained and matched with field observation crop phenology stages. These remote sensing derivate phenology dates were compared to National Agricultural Statistics Service (NASS) weekly crop progress reports to evaluate the capability of these datasets in temporal sensitive studies. The results illustrated that daily surface reflectance datasets were the most accurate source for time-sensitive studies. However, extra ancillary datum and appropriate denoising techniques should be applied to reconstruct the time series curve. Phenology matching process is a necessary step before detecting phenological information from remote sensing imagery for specific land cover type since same phenological stages of different crop types might have different counterparts on time series curve.
Document type :
Conference papers
Complete list of metadata
Cited literature [33 references]  Display  Hide  Download
https://hal.inria.fr/hal-01360974
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, September 6, 2016 - 3:07:02 PM
Last modification on : Tuesday, September 6, 2016 - 4:07:31 PM
Long-term archiving on: : Wednesday, December 7, 2016 - 1:29:51 PM
File
978-3-642-27278-3_16_Chapter.p...
Identifiers
Citation
Hu Zhao, Zhengwei Yang, Liping Di, Zhiyuan Pei. Evaluation of Temporal Resolution Effect in Remote Sensing Based Crop Phenology Detection Studies. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.135-150, ⟨10.1007/978-3-642-27278-3_16⟩. ⟨hal-01360974⟩
Share
Metrics
Record views
86
Files downloads
74
