New interface
Conference papers
Research on WSN Channel Fading Model and Experimental Analysis in Orchard Environment
Abstract : The wireless sensor networks used in large-scale orchard must be able to run in various environments including different heights and densities of fruit trees. Moreover, as the radio channels have different propagation characteristics in different environments, it is important to study the propagation characteristics of wireless channel in orchards environments. This paper studied the propagation characteristics of wireless channel of 2.4GHz and 433MHz in orchard with different peach tree heights, respectively, and the channel fading and PLR (Packet Loss Rate) were tested. After that, the transmission range and PL (Path Loss) of wireless channel with different antenna heights were analyzed, and the communication channel fading model was also established. It can be observed that antenna height influence on the frequency of 433MHz is slightly larger, but the initial path loss of 2.4GHz wireless channel is greater. And it also can be found that the antenna height of 3.5 meters is better.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01360998
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, September 6, 2016 - 3:12:49 PM
Last modification on : Tuesday, September 6, 2016 - 4:07:31 PM
Long-term archiving on: : Wednesday, December 7, 2016 - 2:08:36 PM
File
978-3-642-27278-3_34_Chapter.p...
Identifiers
Citation
Wei Zhang, Yong He, Fei Liu, Congcong Miao, Shitao Sun, et al.. Research on WSN Channel Fading Model and Experimental Analysis in Orchard Environment. 5th Computer and Computing Technologies in Agriculture (CCTA), Oct 2011, Beijing, China. pp.326-333, ⟨10.1007/978-3-642-27278-3_34⟩. ⟨hal-01360998⟩
Share
Metrics
Record views
78
Files downloads
111
